Abs and slip light together you should check your wheel bearings if you are having a week feel in your brakes at the same time. Bearing wobble will also push the piston/pad back in the bore and use up pedel travel presenting itself as a soft pedel.I have a similar feel in my brakes, and the abs and slip lights are on.
Did you find your problem?
