Hi there, so i took my throttle body off, so that i can install a throttle body spacer(3.3L V6). Installed it, and place the the throttle cables back to there place as they were before. I went out for a drive, and it took for ever to change from 2nd to 3rd gear and when it did change.. the rpm's increased high.
I got on the freeway for a bit and it took a long time to change into all gears and it seemed to top of at 40 mph.
The truck is strong and the idle is good though, turns on fine!
So i believe is something to do with my throttle cables, maybe the adjustment on them is off? The adjustment on the throttle body sensor position?
I have no clue!
Anyone have any ideas?
Thanks!
I have no clue!
Thanks!
