I loaned my 04 Frontier to my parents for a few days this past week. When I got it back my headset will only play through the tweeters, not the 2-way speakers on the doors. I asked my Dad, & he said aside from turning on the radio he didn't really adjust anything.
Solutions I have tried so far:
-I searched through every menu on the Pioneer headset & adjusted every audio setting-didn't fix the problem.
-I looked up the fuse locations & checked all the fuses-none are blown
Things that I haven't tried:
-pulling the headset & checking the wires
-figuring out where the amp is and checking that (I'm assuming there is one based upon there being a separate fuse for Audio Amp.)
Anyone have any input as to where I should go from here? I'm going to be putting the stock headset back in as I will shortly be selling it, so I'd like to figure this out before I pull the Pioneer.
Also - when my buddy & I wired in the Pioneer it did something to my airbag system because now it constantly blinks on the dash. I checked the 'passenger on/off' switch on the dash & that is properly plugged in.
That plug was the only thing that was touched as far as the airbag system goes. Can anyone give me a direction to search for the cause of this?
Thank you!
Thank you!
