1 - 4 of 4 Posts
About to install the SPC UCA on my 2012 frontier this week sometime. I'm currently running radflo 2.0 coilovers. I am going to also install a 1/2" spacer as well. I was wondering if you had any recommendations on caster set up for my truck. Because these UCA are SO adjustable was hoping for some input on best initial set-up.
Thank you in advance!
Just grind the coil bucket down about 1/2 inch , then get the ball joint boot as close to the ground down coil bucket with out the ball joint boot touching. Anything but this your tires will look like a this \ / from the front.
Reactions: Frontier510
When I put mine on. I had the ballpoint pushed all the way in, in the slot. In “+1” position. Inner mounting bolts in. Ball joint unattached from spindle. Then pushed it down till it touched the coil bucket. Traced out a notch for the ball joint and went to town with a 4 1/2” grinder. I then double checked it. Hit with some paint, so the edge wouldn’t rust. Or at least slow it down. And away I went. It’s not hard. Don’t over think it. If it clears before you hook it up to the spindle, then you’ll have more room when you do attach it.
Yup, get friendly with your grinder. I have my spc set for 2 degrees casyer and slid all the way in for camber. LCA cam bolts tweaked it from there for 0 camber and all the caster.
Just triple check the clearance fit of the ball boot past the CB. Or you'll go through bj annually.... or make a mess monthly.
If you havent seen it yet, Brutal has a guide for setting the bolts to fit 33s also... so you set those then tweak the spc.
1 - 4 of 4 Posts
