This might sound stupid but since i have oversized tires. Can you still use the factory spare tire under the bed if something happens to one of my tires. Safe to ride that one tire would be a different size then the other three?
Thanks
Thanks
I was told w/my lift it will work but only in the rear.This might sound stupid but since i have oversized tires. Can you still use the factory spare tire under the bed if something happens to one of my tires. Safe to ride that one tire would be a different size then the other three?
Thanks
x2The key to remember thou is that you should not run the spare on the rear axle since it will cause the smaller tire to spin more and if it is off enough, it will cause driving issues. Also, if you are 4wd, running the spare on the front also causes issues with the diff even thou the 4wd may not be engaged.
Overall its not ideal but is doable for short distances.
And thats the way to be, good deali picked up a used 285/75/16 at a tire shop for $35 mounted and balanced.
