1 - 3 of 3 Posts
Dose any one have a spacer or OEM coil over or aftermarket coil over out of their truck. I need the measurement between the bolts, ie how far apart are they from each other. Thank you.
2"15/16 between the back two and 3"3/8 between the back ones and the front one cause there not evenly spaced the back two meaning the two that are away from the wheel while mounted in the truck and the front one being the one in the front closest to the wheel hope that helps and thats from center to center on a oem strut i had in the shed
1 - 3 of 3 Posts
