1 - 20 of 29 Posts
So on a recent trip to 4Wheels parts, i was talking to the guy about installing my soon to be ordered coil over and he said they would not do it because they were not a dealer and therefore did not install parts. He offered me icons but i told him i was not interested because i could not add a spacer on top to get 3 inches of lift and not max out the coil over.
He went on to tell me it was a terrible idea, i would bind up my CV shafts and joints and destroy it all offroad. Especially on a 4x4 truck.
My goal is to get the PRG Advanced coil over kit with a new upper a arm and add a 1 inch spacer in the coil over set at 2 inches to not max it out and have a rough ride. Is this a bad idea??
The guys fro Nisstec have said that a 1 inch spacer won't be a problem, more an it will. Inputs on this anyone??
PRG Products
You would not max out the coilover with either the Icons or the Radflos. You are just moving everything down an inch.Your control arms angle remain the same with the spacer or not.Your shock shaft exposed/ non-exposed will remain the same.
What changes is your droop/bump
Percentages depending how much you change your ride height.
Well the purpose of me adding the spacer is to not have too stiff or a ride. When adding the one inch spacer on top, i will have more droop and that is what the guy told me to watch out for. Too much droop would bind up my cv shafts since everything would be pushed down.
He said he did not recommend it but if i did, look into a living strap. Even then he was against it.
How do you figure by adding the spacer it will lessen the stiffness of the ride?
I mistated in my reply that the control arms angle remains the same.I meant to say the control arm angle remains the same whether you use a spacer or use the adjuster.
Same with the amount of droop.
By raising the truck it reduces the droop.The problem is not having enough droop.
You don't have enough droop or either does a stock suspension to bind up the cv's. Bucket arm contact would not allow it.
Limit straps would be necessary if the arms could pass the buckets which they can't.
Wouldn't the spacer give you a stiffer ride?
Sent from my SM-G900V using Tapatalk
No,why would it? Let's say it takes 1000lbs of Spring rate to maintain ride height. The 1000lbs. does not change by adding a spacer or using the adjusters. Does the spring compress more when you do this?No,it remains the same.
Just going by what I have now. Im running a lift spacer on top of the stock setup and it rides like **** off road. I bounce like a pogo stick.
If it pogos, it seems like your shocks are not dampening. You sure the shocks are still good?
They are your stock shocks and springs, right?
Only thing I can suggest is to take out the spacers and see if it reacts the same off road as it does now. Obviously something is not right.
If it road better without the spacers than you should remove them but I really don't think that is the cause.
If you think the spacer made it stiffer than there should be l even less pogoing.
If you had no springs,just a solid bar replacing the shocks there would be no pogoing at all,right?
Pretty sure it's because of the stock UCA's. No room for travel. I purchased some Radflo coilovers and SPC UCA'S that I'm gonna replace everything with.
Is it pogoing or hard abrupt hits?Are you getting coil bucket contact? Big difference than pogoing.
The SPC arms will help with coil bucket contact but very little to increase travel. They are stock length arms.
Starts slowly and progessively gets worse till its pretty abrupt. I have to slowdown or stop to make it stop.
Another question.When you put in the spacers did you do anything to the rear suspension?
If you only put in spacers and it started to pogo than maybe it was caused by the spacers but I doubt it would.By just putting on the shackles it changes the suspension dynamics.
For example,I just changed out my suspension completly.I took off the PRG/Deaver race pack with a custom Deaver spring pack(increased lift).It seemed like the rear springs were too stiff. Re-valved the front shocks and it cured what we thought were the springs.
Too many variiables. To me when the pogoing gets so bad you have to stop,it sounds like it's the terrain. That is what happens when you hit whoops.Unless the terrain was exactly the same when it was stock,you cannot know the cause.
Good luck.
Discussion Starter · #19 ·
I was just concerned over having CV joints destroyed but it does not seem to be the case i guess. Seems like a lot of people do it. Th big issue i goes would be not having sufficient shock travel.
Now as for the spacer making the ride worse, i do not see how that would be as you would only be raising your shock mounting position.
Yes , too much droop can cause cv damage(so will too much bump travel). Like I said before,the coil buckets won't allow it to happen.
You can see that I have no coil buckets which would allow the cv axles to over extend(old front suspension). By using limit straps you can prevent this. I use limit straps and bump stops to protect the shocks. If you set-up your suspension correctly(compressed/extended length of the shock is correct,shock shaft percentage is correct,etc.) then your cv's will be protected also.
If the seller,fabricator did his job,then there should not be a problem with a shock having having insufficient or too much shock travel.
By raising your truck 3",whether with spacers,the adjusters or a combination of both severely limits your droop. This might be alright if you keep it on the pavement but not off road.Especially rock crawling where you need need a lot of droop I have been told.
1 - 20 of 29 Posts
