I like all this, giving me great ideas. We think the same way on the tint, that’s another on my to do list, I go to work with the sun in my eyes and come home with it in my eyes - time to fix this.
Radar Detector - Uniden R3 hardwired and modified w/ extended power and alert leds and extended toarmrestcruise control switch mute button
Bed lights - Installed with photocell switch on dash & reed switch on tailgate for prevention of accidental battery drainage
Autoloc one touch window modules w/ PAC-TR7 universal triggers to operate windows with keyfob/remote
Code Alarm CA1553 w/ 5 sirens (originally had wired in a dual zone proximity sensor to roll up windows when triggered. It worked but I had to ditch that feature)Alarm -
Installed a reed switch inline between SECU unlock wire and ground under my cowl vent (unlocks w/ magnet)NEVER LOCKED OUT MOD-
Autometer Spek Pro Temp Gauges - engine coolant temp and trans temp
Electric Fan System -
Motorcraft GL-421 modified and installed125 Amp Alternator -
Would love to hear your thoughts on the dynamat install. Was the reason to reduce road noise, and if so, did you find it made a significant difference?Dynamat and Dynaliner install on doors, floor, roof and rear wall
I don't know what the Mercedes Benz door closing sounds like. The only comparison I can make is the difference between the closing of a hollow core and a solid core door in a home.YEG, I've only done my doors so far and even that was a very noticeable difference. Closing the doors now makes a very satisfying, solid thunk like a Mercedes Benz S-Class closing.
In the Spring, I'm going to do rear cab floor and the rear cab bulkhead below the window, Raine noted that that made a significant difference, as well.
To insulate and reduce road noise. Significant difference especially in the temperature of floor and tunnel. I'll install it on every vehicle I own from here on out.Would love to hear your thoughts on the dynamat install. Was the reason to reduce road noise, and if so, did you find it made a significant difference?
Yessir. And I wired them up, in the best way that I could think of, to be worry free. Worry free in regards to accidental battery drainage.wait...bed lights??
Okay, think difference closing a Geo Metro door and a Cadillac XTS door. One rattles, and sounds tinny and hollow. The other sounds more like a bank vault closing ka-thunk. That's how I'd attempt to describe it.I don't know what the Mercedes Benz door closing sounds like. The only comparison I can make is the difference between the closing of a hollow core and a solid core door in a home.
Are you talking about the Cargo Light above the bed, or lights inside the bed itself?Yessir. And I wired them up, in the best way that I could think of, to be worry free. Worry free in regards to accidental battery drainage.
A few things have to happen in order for them to turn on.
1. Rocker switch has to be on.
2. It has to be dark out or the photocell switch has to be blocked.
3. Tailgate must be open.
If I was parked or driving during the daytime with my tailgate open and I didn't notice that the rocker switch was in the on position...no worries because the photocell switch will keep the lights off.
Never been in one of those vehicles either.Okay, think difference closing a Geo Metro door and a Cadillac XTS door. One rattles, and sounds tinny and hollow. The other sounds more like a bank vault closing ka-thunk. That's how I'd attempt to describe it.
Just like you described the home interior doors..Never been in one of those vehicles either.![]()
thats so simple its scary, i really dig itThere's a tilt bearing type switch in the bulb mounting base of the under hood light and the retractable light that's mounted to the fender well has a on/off lever. Power and ground from the Blue Sea fuse block that's mounted on top of the oem under hood fuse block.
I changed it up and broke off the glass of the hood bulb and soldered the positive wire of a led strip to the contact of the broken bulb which contacts the tilt switch.![]()
