I swear you can see it when driving though even on straight non crowned roads you can see it going to the front right over the dash
I'm sure you can see it, no one is saying you can't. I think at this point it's just one of those "live with it and let it go" type things. Like
@RamTest said - based on your alignment shop's hard numbers, the moment you get into the driver's seat that should (by the numbers) flatten out; what your eyes are seeing might just be your eyes playing tricks on you. Remember: eyeballing stuff is as accurate as a butt dyno.
Just gonna repeat what I posted about a week ago:
Every vehicle will have some "lean." It's normally minimal, but definitely normal.
There is no way you can be 100% sure every single part in the suspension is still even left/right because you bought it used. It would have been safe to assume everything at minimal would have been straight if you just bought it brand new from the dealer lot, but you didn't. You don't know the entire history of the vehicle, and there are countless variables that can be causing that marginal 1/4":
Coil spring sag, shock damping condition, shock resistance, coil spring isolator condition, lower control arm bushing tension, upper control arm bushing tension, lower control arm bushing hardness, upper control arm bushing hardness, rear leaf spring stiffness, rear leaf spring sag, rear shock condition, sway bar straightness, swaybar bushing condition, swaybar bushing wear, ball joint tolerances, body mount condition, body mount compression, fuel tank level, driver weight, cargo weight, cargon weight bias, battery weight, body straightness, bed straightness, tire pressure, tire tread wear, alignment, axle straightness, ground level, ground crown, hood alignment...
You would have to chase and correct/verify ALL of those things (and more) until you identify the issue - if you will even find the actual problem after spending $$$ to correct or replace everything in that list. Until then you can tell us everyday that you can see some "lean" and anyone can chime in and tell you yet another variable that you have to correct first.
