hello all. new to the forum. nice to meet everyone. first off I have an 06 nismo frontier straight shift. I have looked and am having difficulty finding an answer to a question. theres a lot of info out there but I haven't yet been able to find the answer. Hopefully someone here could point me in the right direction or offer some advice.
I believe I have a possible front driver side shaft bearing going at the front diff input. just replaced the hub which was going out and got some improvement but not much change in the droning, bad bearing noise im getting. passenger side hub is tight and no movement in the hub bearing. I have some slack in all directions in the driver side cv axle where it goes into the front diff. I will try to post up a link to a vid here in a little. any way my question; is it possible to pull the bearing with a slide puller of sorts without having to open the diff by going in from the outside? if not could someone explain what would prevent this.
again its great to be here and learn from the many experienced folks. thanks much for any and all help, advice and guidance.
regards,
todd
regards,
todd
