1 - 17 of 17 Posts
I want to put on a nice set of steps. I don't really like the look of the OEM rails, so I've narrowed it down to the 2 I like the best so far and if anyone has used either one your opinions would be greatly appreciated. If you have another one you think I should check out I'd be interested in that too
The first rail is this Tyger star pattern:
The second is made by Lund https://www.realtruck.com/lund-terrain-hx-step-nerf-bars/34641678.html
Any and all feedback helps me out a lot, Thanks in advance!
I like the Tyger ones better. They look more uniform and give you more stepping space
I have the Tyger ones. They look cool and are pretty sturdy. I have noticed getting out of the truck is a pain. The door has to be wide open to step past the bars to the ground. This is annoying when parked next to someone in a parking lot. I have only had them 3 weeks so hoping I figure out a good way to get out. Just my 2 cents.
about how far do the bars stick out? 1 foot or less?
That's the first time I've seen those Tyger ones - I may need to look into that myself... personally I prefer those over the Lund. That is subjective though and the best option is just to go with what you like.
The first rail is this Tyger star pattern: https://www.amazon.com/Tyger-Auto-TG-AM2N20158-2005-2017-2005-2012/dp/B01M0RZ22T
Have the Tyger ones on my Pro4, sturdy and for the most part mount easily, just minor adjustments.
Land vehicle Vehicle Car Automotive tire Tire
they look really good. I think im leaning towards those myself. By minor adjustments, are you talking about the holes not lining up?
I also have Tyger
Sent from my iPhone 7 plus using Tapatalk Pro
I think im going to get those. They look really good on the frontiers, and from what I hear they're sturdy and easy to install
Since the choices you have posted are really more like sliders, I'd suggest taking a closer look at White Knuckle Off Road. You can get them in DOM tubing with a partial or full top plate and the bump out works very well as a step to get to anything on the roof. The bump out is also great for protecting your body work off road.
Here is a link - Nissan Frontier Rock Sliders
Yea the mounting holes were slightly off on the center mounting point, just opened them up a small amount with a uni-bit and on they went. You may or may not be able to use the washers provided I had to get a few thinner stainless washers when I installed mine to make sure the attachment nuts had full thread engagement. Also if you order them from Amazon, be cautious, they sent me two sets for a Jeep Wrangler and I finally had to get them shipped from an alternative supplier through them to get the right set.
Discussion Starter · #12 · (Edited)
sounds simple enough but we'll see what happens when I get them
they look great but may be just a little out of my price range. I will definitely keep them in mind though, they look like they are worth the extra few $$
It really comes out to are you looking for steps or rails... Steps that are mounted to the body are great for on-road use and LIGHT off-roading (fire roads and other moderately maintained surfaces) but if you're going offroad the protection a rail provides is night and day. Even a good, solid tube style step (like that tiger) will cause damage to the rocker mounting and eventually the rockers themselves. But this is under the presumption you are in the rough.
Discussion Starter · #17 ·
I wont be taking it anywhere crazy, and my girlfriend is short so if/when I get a lift she wont be able to get in the truck too easily. I don't need much protection, but I really don't like the OEM running boards
1 - 17 of 17 Posts
