1 - 8 of 8 Posts
2019, Nissan Frontier SV 4x4, Arctic Blue.
running the wire through the factory boot is probably the most difficult task. Use a small/medium sized cable tie, some sort of lube to help it slide through, and E tape to compress the wires to the zip tie to help fish the wires through.
'22 SV King Cab 2WHD
Hi Lukesbouldergrey, I've figured out why you didn't run your wires thru the rubber wiring hose. When I finally got that off and saw it was just one big connector, what a surprise. I'm wondering though, was there any way of using the service connector rather than running all of that wire? Great video - showed me what I needed to see.
1 - 8 of 8 Posts
