1 - 10 of 10 Posts
I installed the bumper on Saturday. Overall the bumper is great, high quality and the directions were good. I found it hard to get the stock bumper off, I did not know you had to take off the grill. Right now the truck has the stock front suspension, I don't think it settled that much, look like less than an inch. So now i need new shocks. What is the stock spring rate for a Frontier (stock SE 4x4) and a Titian? Also what spring rate do you recommend?
When I started, I took the bull bar off a few weeks ago.
After the install.
From the side.
Does this ^^ look bad, can damage occur from the angle of the control arm. I let the truck settle some (overnight) before I took these pictures.
wow bumper looks good but thats the first time ive seen anyone with there 4wd shafts pointing upwards :) i would say you need a couple inches lift in the front i would suggest adjustable coilovers if you got the cash so you can adjust them where u want them for the right ride height call greg at PRG Products hell know exactly what you need
Yea, I know I need new shocks badly, I am thinking about getting 2.5 coilovers at 750lbs spring rate if I can, because I though stock was around 600lbs. I don't want to so upper arms, I was only planning on doing an inch or 2 compared to stock in the front and 2inches in the rear. I would like to keep the load caring capacity of the rear end, the best would be to increase it if I could.
Nice looking bumper.
Stock spring rate is 500lbs. 750lbs is way to much.
Get the Icon coilovers from nick. Prerunnerparts - Home You get them for stock control arms.
bumper looks great, how long was the wait?
Any of the aftermarket coilovers should be fine as long as you can adjust the preload to compensate for the weight. I use the radflo 2.0's and they have been more then sufficient, but there are definitly lots more options now then there used to be.
I like those because of the coating on them. I also want their rear shocks, that they don’t make yet.
What spring rate do you use?
looks great, how long was your wait?
I think was about 15 to 16 weeks. I had the bumper in the garage for a few weeks before I could install it.
i just sold my rad 2.0's to a guy on thenewx hes currently running 750lbs springs and hates it said it rides like garbage even with a shrock bumper and winch to stiff he wanted mine because they have a 650lb spring
1 - 10 of 10 Posts
