1 - 9 of 9 Posts
So I put on some lift schakles and cranked the torsion bars, but I could only crank them so far because the shocks are too short... What I mean by this is almost every time I go over a bump I can feel the front end hit the top of the shocks. I can feel them extend all the way and come to a hard stop. Has anyone ever delt with this problem? Is there a quick fix? Can I just stack a bunch of nuts onto the top of the shock?
Either get longer shocks or crank your t-bars back down some. Those are really the only safe options. Adding nuts like you say is not a great idea.
Just asking to increase my knowledge about 1st gens but do they have any kind of shock buckets? I know they have Tbars instead of coils so that is why I called it a shock bucket instead of a coilbucket.
Discussion Starter #4 (Edited)
Do you know where I can get some longer shocks? I really don't want to crank them any lower, the truck still sits lower in the front then in the rear, and I hate that.
I wonder if such a thing even exsits, all I know is my Tbars can be cranked more but the shock's short length keep me from doing so
the only option is to add slightly longer shocks.
4x4 parts
Discussion Starter #7 (Edited)
How much longer should I go?
I can't find any shocks shorter then an additional 3 inches. Should I just use those? The ones intended for a suspension lifted Frontier
Are you 100% sure its the shocks and not the UCA hitting the bump stop. Remember they're 2 bump stops.
Discussion Starter #9 (Edited)
I think it is the shocks because they are brand new I installed them when I installed the lift shackles. The front end never hit like that before I cranked the Tbars... I think I should into the UCA just incase?
I went to my local Truck shop today and found a shock that I can order in any extra lenght I need, they are called superlift of supershock, something like that. Should I invest in those? Ever delt with them?
1 - 9 of 9 Posts
