I was trying install my 1.5" shackle on my frontier last night. But I can't seem to get the spring to drop enough to hook up the new shackles. I am pretty sure it's the shocks stopping the axle from dropping more. Also the brake lines are almost tight as is.
I can unhook the shocks to hook up the shackles, but will I ever get it back together and will I be over extending the shocks?
Unhook the shock. Then use a jack to get the axle back up. I ran a 1.5" shackle with my stock shock with no problem. Except for the shackle flattening out my leaf packs. I've since swapped the shackles for the Deaver aal's.
Sent from my SM-G900V using Tapatalk
I had the same problem with stock rear shocks.
The above from ideas from Chris and Robb are probably safer than what I did.
I just took the stock nissan scissor jack and wedged it in between frame and the leaf spring and extended the jack until I could line up the holes on the leaf spring and shackle.
But be careful the jack popped out on me once, it was pretty sketchy.
Thanks for the replys.
The lower shock bolts were seized in, but I ended up cheating with some c clamps.
Also I see what you guys are saying about flattening out the leaf pack. It seams worse than other vehicles I've had shackle lifts on.
The end result with 265/65R17. I have a set of 255/75R17 to be installed.
Great idea with the C-clamps !!!
A lot less dangerous than wedging the stock scissor jack in between frame and leaf.
