A simple cheap thing to do is to disconnect the negative terminal and touch it to the positive, this will discharge the capacitors in the system. Then leave it unhooked over night and re-connect in the morning. If the code is a mistake, this should erase it.
Past that it may be worth investing in a real scanner.
