Make NAPA feel sorry for ya and they might run outside and scan you up for free.
You can get yourself a USB OBD II adapter on ebay for pretty cheap, do all of your own diagnostics, most the time come with some pretty alright software.
Most shops wouldn't charge you much.
The most that a shop will be able to tell you is the code that your truck is throwing... mine right now has the check engine light on, the code it has is a P0420 for Catalytic converter problems. Nissans computer software ( called CONSULT) is made specifically for nissan's trucks and will allow a much more in depth and detailed electronic diagnostics...
I'd say get it checked by a local shop my napa or parts Plus, if they don't get ya for free, should be around $20 or so... takes them no time. Plug their handheld scanner in, hit scan, give you the code and what it means, they ask for $20. If it's a code that doesn't give much description and could be SEVERAL things causing the code to trip, THEN take it to nissan and pay the bucks.
