1 - 1 of 1 Posts
1: stainless steel rods: round bar, hexagon bar, square steel, flat steel, hexagonal, round, solid bar hexagonal and square steel rod (flat) than your rod, (the Company hexagonal rod specifications for the import quality materials). your bright side than the black surface. large-diameter rods, mostly black bar which is 303 rods in a specific material, is easy to drive (cut) -type materials, mainly used for automatic lathe cutting another:. 304F.303CU.316F also are easy-cut materials.304 stainless steel wire suppliers
2: stainless steel (Stainless Steel): Or call roll, roll, coil, the coil is called more, the hardness of the strip, there are many, ranging from tens to hundreds of former customers purchase must first determine which handy hardness (8K mirror brightness) coil width uncertain, there is:... 30mm.60mm.45mm.80mm.100mm.200mm points, etc. can also be based on customer requirements.Flat Plate Steel For Sale
3: Stainless steel wire: also known as stainless steel wire, rod, plate element, but with different stainless steel wire rope wire and screw the main spring wire line two kinds, as the name implies: screw line is mainly used to make screws and the spring line is used do spring or other requirements of flexible metal other products, such as bright line, back line of hydrogen, electrolysis line, axle hairpin lines have spring wire tensile strength hardness of 1500-2000 are the following:... all soft | 1/4 hard | semi-rigid | 3/4 hard | full hard | special hardware wire rope specification: 7 * 1,6 * 7,7 * 12,7 * 39 * 19, 17, etc., than the same material line, bar. , tubes, plates to be expensive. 7 * 7 for the most expensive shares.304 Stainless Steel Flat Stock
1 - 1 of 1 Posts
