2001 supercharged w/ approx. 200 K miles...was thinking about using Seafoam in the crankcase, but a little leary about running it through the air/fuel system. Anyone have any experience with this stuff either pro or con? Don't want to risk any expensive damage. Thanks
I did it about a month ago. Sprayed/poured that **** into everything. Intake manifold. Cylinders. Gas tank. You name it. Let it sit for a few hours, started it up, then drove around the block a few times. Did a pretty good job cleaning gunk off piston heads too.
I've used it a number of times on multiple vehicles. I definitely notice a difference afterwards. I slowly induce about 1/3 of the bottle thru the vacuum line connected to brake booster. Just induce slowly. The vacuum will actually suck it in as you pour. I usually let it sit for about 30 minutes before I start it back up to burn off the deposits. I replace the spark plugs afterwards. Don't know if I'm wasting money by doing that nor do i care. But if my plugs are fairly new.... I'll put the previous old set of plugs back in just for the Seafoam treatment. I'll add 1/3 to the crankcase if it happens to be time for an oil change as well. The final 1/3 of the bottle goes into the gas tank.
Sent from my SM-N910S using Tapatalk
Be considerate of your neighbors if you Seafoam your engine. I didn't pay attention to my surroundings the very first time I used it and I didn't even realize the wind sent all the smoke directly to the neighbors at the end of the culdesac where my folks live. I couldn't apologize enough for disrupting their BBQ. They've known me since I was a kid and knew it wasn't intentional. To this day they still give me a hard time about it whenever I go visit my folks. The first thing they ask when I go to say hi is..."So did you come just to smoke out the neighborhood and leave again?"
Although I've used it, I'm now alittle leary about usin it in the crankcase. Last time I did it in a 4.8 GMC it dissolved what was left of the oil pressure sensors diaphram causing a massive oil leak.(which of course I didnt discover until 5pm on the side of 75/85 in downtown Atlanta.)
Not the ritzy side of town, huh?
