What do you look for in Engine Load? I just got the ScanGauge and was just looking at what to monitor on my truck.Engine Load (helps predict transmission behavior), water temp, MPG real-time, and a custom gauge- accumulated MPG for the current trip
Yes- make an X gauge for the 'day' or 'tank'... not sure of the codes- see the instruction manual. Also if you hit the menu button as soon as you start the car, sometimes the current trip gauges will not reset.RPM, MPH, AVG MPG, Water Temp
btw, does anyone know if there is a way to have a avg mpg that doesn't reset every time you turn off the engine?
