Ok guys so if anyone has ever wondered what u need to do to run 20s and 33s and clear without having to trim +3 inches on your finders I have a guy that did this to his 2wf in Hawaii and he said he has little to no rub and did minor trimming
His build is a fabtech 6 inch suspension lift with a 3 inch body lift (for clearence) he is running 22x14s with 33 inch tires. He is running 1.5inch wheel adapters all the way around for a different bolt pattern
Soo with this being said my intentions are to basically build a 6 inch kit without the cost of a fabtech lift kit. So my build will consist of:
Titan swap
CTS spindles
And a 3 inch body lift for the front. This should allow 7-9 inches (depending on how my Titan swap goes) before the body lift
As for the rear I'll be doing this:
Custom leaf springs combined with Titan and frontier leafs
Shackles
And possibly some blocks to make up for 6 inches in the rear before the body lift
I'll post a pic of his truck below so you can see what his truck looks like and as soon as I get all mine done I'll be sure to add pics with mine.
Hope this may help people who like me want to run 20 inch deep dish rims and 33 inch tires.
Sent from my Z988 using Tapatalk
Titan swap
CTS spindles
Shackles
