1 - 2 of 2 Posts
This is the basic kit essential for an Axle swap, more items could be added but this is the bare minimum, You will receive 1 pair of our 3/8" thick A50 Steel U-Bolt plates with 3 pin mounting options, a pair of our Spring Perches with the same pin option to match, 4 - 10" x 5/8" Fine thread Grade 8 U-Bolts with 1/4" thick cut Hardened washers and real Ubolt Hardened Tallnuts, and a pair of Shock Brackets. This will get your Axle under the rig. BTW, this is NOT a Chinese made product that just can't hang with the big kids, this IS the Big Kid.
These go for $127.50 a kit before the Discount!
BTW, our Ubolts are the correct size for your Axle, not 1 size fits all.......these are offered with 8 Axle diameters and 5 Leaf Spring perch widths.........UPDATE.........Now also available in 3.5" D70/Sterling diameters & D60 GM, Ford, & Dodge front swaps too! And I almost forgot, Ford fullsize 3" Leaf Spring widths also......
Axle Swap Kits - RuffStuff Specialties
1 - 2 of 2 Posts
