2017 Pro-4X w/Luxury Package
So step 1 was having the VSS replaced and the wiring tested to the cluster. Put on a live-data OBD-II reader and it showed everything normal except the VSS staying at 0 and never changing.
Then I sent the cluster out to Mr. Whizard. Nice bunch of folks. They tested it and found everything fine.
So now once I get the cluster reinstalled, I am at a loss as to what to do next.
The speedo and odometer died right when I disengaged the cruise control. Is it possible that the cc switch went bad and is shorting out the circuit somehow?
Guess I'm probably headed to the dealer next unless I can come up with something else.
Nissan Frontier Factory Service Manuals
I don't know if you have looked at the factory service manual yet. If not, there is a diagnostic procedure for speedo/odo not working. I looked it up for my truck a 2002, and it was on page 80 of the EL (electrical systems) I'm not sure what your truck/engine is, hope it helps.
Yeah, I have - thanks - been through the tests, either me personally or the local shop. That's why I sent the cluster out for repair.
It's a real cluster foxtrot LOL.
Thats to bad, everything points to the vehicle speed sensor, but if that's good......... Now my next idea, and I would want you to get a second opinion to make sure it won't do more harm than good. You said it happened with the cruise control, what if you disconnected the cc, and tried, on the off chance that it is a a cc problem. Just throwing here spitballs, to see if anything sticks. Good luck.
Cannot fix your issue but you can always use a GPS for a speedometer.
