Rough Country loaded struts.
829 Views 8 Replies 4 Participants Last post by  RidgeRebel
Looking to get the Rough Country 2.5 loaded struts for my 2012 SL 4x4. Has anyone installed these and if so how hard was it. Thanks.
1 - 9 of 9 Posts
Installation is like any other strut. Get the cam bolts. You will have coil bucket contact with the stock UCAs.
The struts are nice and ride well.
Reactions: 1
Coil bucket contact won’t be an issue on the street, and it doesn’t look like that truck’s seen much time off-road. Installation isn’t bad, cam bolts are a must unless you want crazy positive camber. I’ve been more than happy with mine for over 30,000 miles.
Reactions: 1
How did they go in, do you have to loosen the upper ball joint or will the go in like a stock strut? I just picked this truck up. I don't think it's ever been off road.
Loosening the upper ball joint makes it much easier.
Reactions: 1
Looks like RC now makes 2 different loaded shocks: the N3 and the M1. THe N3 are twin tube and the M1s mono. In general mono tubes perform better. Another option the M1 have is ride height adjustability. I can not find any details on how they adjust, but I suspect they are clips that adjust the bottom perch height thus changing the spring preload and the ride height. They claim this prevents "over extending". But if the height is based on preload, this would not prevent overextending and CBC. humm need to learn more.
M1 Loaded Strut Pair | 2.5 Inch | Nissan Frontier 4WD (2005-2023) | Rough Country
As far as installation goes. I have always popped the upper ball joint from the knuckle. If you read, many people are able to simply strike the knuckle with a hammer and the BJ will pop.I have found this to be unreliable. I always use a puller. I have used this pitman arm puller for the BJ 10s of times and it works great.
Tie Rod and Pitman Arm Puller (harborfreight.com)
Reactions: 1
Yeah, I’m a little curious about those too. My N3’s are still holding up well, but they can’t last forever.
Reactions: 1
The N3s are a good buy and I’m very happy with their performance but the M1s may be an option in the future for me too. Hopefully we’ll be hearing some reviews soon.
1 - 9 of 9 Posts
