1 - 7 of 7 Posts
I have an 04 frontier cc lb and was wondering if anyone out there is using the factory roof rack as a kayak rack or do they sell something that would work a little better.
it is rated at 125lbs if that helps. the oval cross braces don't make sticking anything up there easy.
I picked up some adapters to put my yakima round bars on the stock rack. If you do that with the yakima cradles, you can pivot them down when they're not in use. Otherwise, you could use the mighty mounts to put the saddles on the stock cross bars. Here's the best pic I have right now
If you go to Yakima's website, size the stuff up for the Xterra, all of it is common with the larger diameter bars.
Discussion Starter #4
Do you know where I can get the adapters and the yakima rack you have or can you give me the part#s?
The adapter things are
LowRider $220/4 (4 req'd)
Part # 8000118
HullRaiser $100/pair (1 pair per kayak req'd)
Part # 8004039
You'll also need some 48" crossbars, which run $70 for a pair
If you're an online shopper, Moosejaw, REI, places like that will carry them. If you're a local shopper, I'd check out your local kayaking/biking/hiking type of shop, or a Dick's Sporting Goods.
or... save the cash and mount it cockpit side down(See My Sig.) and use some pipe insulation to protect the rim of the cockpit ( also helps keep it from sliding on the crossbars). It'll stay put just nicely.
They also sell some formed foam so you can put it cockpit side up. I think those kits run around $25 (has 2 pcs of foam and 2 straps).
1 - 7 of 7 Posts
