Rocker panel protection?
3501 Views 16 Replies 10 Participants Last post by  The other Sean
So I had the truck out in the snow, now I have a good indication of where stuff will hit the body. Any suggestions on what to use to protect it? Automotive parking light Tire Automotive tail & brake light Car Automotive lighting
Tire Motor vehicle Wheel Automotive tire Tread
Wheel Tire Car Vehicle Automotive lighting
1 - 17 of 17 Posts
Some OEMs use a clear bra type protective sticker that does protect, but winds up looking pretty ratty. It’s a good sacrificial barrier.
Better larger mudflaps would do the job too.
I was pleasantly surprised with the snow performance of my new truck. I hope you are too.
Reactions: 2
Yes, snow performance has been great. We had a bunch of ice before the snow and the truck did pretty good on stock tires. Of course there isn't a lot that you can do for ice.
LaminX has some 2022 frontier-specific clearbra protection Search Results.
Edit- well crud, you'll have to plug in your vehicle details since the link above didn't save my search.
Reactions: 1
It's a bit extreme, and it will require either some skill or having a shop do it. You could put some "bed liner material" in a strip along the lower edge.
The bed liner material is a bit thicker and heartier than standard paint, and it will provide some contrast to the red. It's also available at both Amazon and most parts stores.
I recently purchased six cans for about $70, which would be plenty with lots leftover for your next project.
Good luck!
--Exco
I have seen moisture get under bed liner coatings and completely rust the metal underneath. All the water that rolls down the side of the truck hits the lip where the bed liner ends. Some gets in. It’s not usually a problem in the actual pickup bed because the edge is normally up under the rail.
  • Wow
Reactions: 2
sliders sure help the side of the truck!
Reactions: 2
You might want to consider that the right step bars will protect the truck. As I suggest this I will admit that I am torn up about the suggestion, because the truck is low enough that it doesn't really need the step up to get it to it. The steps do look good though, so it’s something to consider.
Reactions: 1
I looked at step bars but like you said, the truck isn't really that high that I need those to get in. I don't mind the idea of spraying bed liner but if I did that I would want it done professionally lol I'm not that confident I wouldn't make a mess!
I'd go with paint protection film (PPF; clear bra). They range from pretty thin (like Lamin-X PPF) to super thick (Xpel or 3M black label).
PPF has a useful life of about 3-8 years depending on several factors (film thickness, environment, how often its waxed, etc).
Reactions: 3
The film on the fenders of my 2008 taco still looked great when sold it last month despite many years of wet and gritty winters. Quality of the film matters a lot, 3M stuff seems to hold up well.
Reactions: 1
Bump to see if anyone has purchased pre-cut clearbra for their 3rd gen frontier. I see a few options with a quick Google Search, but would like to get some recommendations before buying.
I got a price from a local shop for $370 cad. That is 12 inches wide running from front wheel to back bumper. Haven't decided yet.
A month or so ago, I ordered a kit from PRECUTPPF.STORE. I picked up the Precut Partial front kit out of 3M Pro material. The fitment seems great but I am still learning how to properly lay it down. Had lots of bubbles, but they are going away as time goes on (as good PPF should) I have only done the hood and fenders, since the weather has been kinda crappy here lately. I plan to do the rest of the kit when the weather is cooperative. Still trying to find a good ratio for my slip solution though. Suggestions welcome.
As for the original question, I'd definitely go with PPF if it were a concern. A decent brand is invisible when installed too. It is inexpensive, easy to install on large flat areas (bottoms of doors and fenders) and is very durable. Plus you can always peel it off and replace it.
Films ant the such are just a band aid. As soon as they are nicked with a big enough stone the moisture can get under. You need more mud flap. I went with a pair of Rally armor ones on the rear of my 2nd gen for exactly the pic you posted. My rear bumper was filling up with snow.
If the preparation is done correctly (ie. scuffed/sanded/etched) the spray on bed liner will protect the bed longer than the truck will last. I dealt with vehicles, mainly trucks, on a daily basis at a body shop I worked for. The line-x and similar brands have stepped up their game over the last 5 years or so and are utilized in so many applications, including fender wells and rocker panels. Some can even be done in various colors as well. The material is tuff and lasts.
PPF is a basically a plastic sticker that helps protect the panel while one can still enjoy the factory color. It’s a clear bra that is meant to be a sacrificial layer that can be removed and/or replaced easily.
As of today’s date, there really isn’t any other aftermarket mud/splash guards available for our Frontiers other than Weathertech, which seems to be a similar size to OEM, and a few “universal” ones that may look decent, but unsure. ??
Really surprised Rokblokz hasn’t made ones for the 22-23 version as they have them for the 2nd gen?? Those seem to be a bit lower and a hair wider.
I have been thinking about adding a few inches of length to the bottom of the stock front flaps to help block the chips/splatter?? Was thinking of just going to Wally World or similar, getting a set of cheap thick rubber flaps, cut the bottom ends off and put a couple screws/bolts/nuts through the oem and cheap flaps to extend the bottom?? 🤔
1 - 17 of 17 Posts
