1 - 3 of 3 Posts
I'm wanting too add a 20inch rigid industries light bar too my front end. So instead and drilling a hole and using their switch, has anyone wired one too a otrattw switch instead? I want it too look factory install with the others.
Sent from my SM-G955U using Tapatalk
When I decided that I no longer wanted to have the Fog Light switch control my light bar I picked up a small clean rocker switch and installed it in the rubberised patch just under where our keys hang as it was really simple only needing a drill hole to install and very easy to gain access to. Also if I should change my mind somewhere down the road I can replace the rubberised patch and have no visible hole remaining in the dash...
1 - 3 of 3 Posts
