1 - 2 of 2 Posts
So i need to reset my ecu to see if it will fix my trans shift points.
I assume i should revert superchips to factory default and than reset the ecu? How long after resetting the ecu does it take for the ecu to relearn everything? I've heard upto 50miles....
Than should i reload the superchips after the relearning curve or it doesn't matter so i should just reload it after resetting the ecu?
Doesn't look like you ever got a response. If you take the tune back to stock and then reinstall whatever tune you wanted, that resets the ECU. I asked [email protected] and he confirmed this. When you have the stock installed, you might as well update the tuner. My experience is that it takes 50 miles to get the LT Trim numbers to start adjusting again. Now, how long until they move to a stable state I have no idea.
Cheers!
1 - 2 of 2 Posts
