1 - 3 of 3 Posts
Does anyone know the correct Nissan part number for a replacement key for a 2015 CC Pro4x with the transponder? There appears to be several different part numbers and I don't want to order the wrong one. I tried the rogue key route and couldn't get it to work. Going to get an OEM key so I have more than one key.
You can go to www.NissanPartsDeal.com and look it up using your VIN # to make sure you get the correct part number. The key blank would then need to get cut and all of your keys will be needed to initialize them to the BCM.
1 - 3 of 3 Posts
