Truck is at right around 30k miles now and coming right up on 5 years old so I decided to replace all the fluids in it and filters since I had a completely free day. I realize it isn’t high miles at all, but hey, now I know that it has good fluid and that everything is on the same timeline. Replaced front and rear diff fluid, transfer case fluid, manual transmission fluid, engine oil, coolant drain and fill, and engine and cabin filters. Took 4.5 hours. (Obviously the oil and filters have been changed per normal schedule and the other fluid has been “checked” by the dealership).
I used Valvoline synthetic for everything because my local stores had it available; 75w-140 for the rear diff, 75w-90 for the front, synthetic D matic rated ATF for the transfer case, Valvoline Synchromesh for the MTF, and Valvoline synthetic engine oil. Fram oil filter, Fram air filter, and STP cabin filters. Pentosin pentafrost A3 for coolant.
The only tricky fluid was trying to find an equivalent MTF fluid. The Valvoline Synchromesh was the only GL-4, 75w-85/90 equivalent that I could find and verify was good to go.
A cheap oil pump is a must, along with a 10mm hex head socket, and a 3/8 driver and torque wrench. Along with a few replacement plug gaskets.
I didn’t see any significant build up of gunk or metal shavings and the only fluid that looked a little grimy was the transfer case oil. That was relatively dark looking.
