Is there anything special needed to remove and replace the axle shaft on the C200k rear? I have a new shaft with the wheel bearing, backing plate and all spacers already pressed on, plus a new axle seal and o-ring. I read the procedure in the FSM and it looks straight forward.
1. Take off caliper and rotor.
2. Disconnect parking brake cable.
3. Unbolt bearing cage from housing.
4. Use slide hammer to pull axle shaft out of housing.
Am I missing anything?
