1 - 20 of 27 Posts
2014 NIssan Frontier SV 4x4 CC
My truck is New-to-Me and came with some dried cement around one of the floor tracks. I did some google-searching and found some mentions of soaking in a vinegar solution. If it isn't damaging to the spray-liner I will give it a try. Does anyone have some other suggestions?
332142
2014 Frontier SV Crew 4x2
Just be careful with any thing acidic due to corrosiveness. You don’t want to start rust anywhere. Yikes!
The chemicals in the concrete didn’t kill it. I’d very carefully take a chisel or screwdriver and chip it away, go long ways to stay away from the bed lining. Don’t chip straight down. Good luck with the truck.
That's what I was thinking too Clint, using a mason's chisel and being patient all the way.
332145
Reactions: stevet47
You might try a wire brush and work at it bit by bit. The spray-on liner is pretty tough and can take some good abuse. Chances are you won’t get all of it off but most likely.
Chipping and wire brush seems like the way...I think I will take the track off of the bed to help dislodge some and then tackle the rest w/ it off. Maybe hit the risiduals with a can of touch-up liner spray? Idk about that part yet.
You may have a problem removing the track due to loctite and age, I’d try to just chip it and not complicate things. A wire brush is harsh, a nylon bristled brush is more forgiving. You can find a grout brush at Home Depot that has a chisel tip that will fit next to the track nicely and about $5.
Ever considered using an oscillating tool with one of those grout removing blades??
Hit it from an angle with light pressure & it should remove the cement....
Good Luck!!
I would got at the thick areas along the the track gingerly with a wide dull chisel and a hammer. Get most of the high spots, leave a thin white layer. Bed lining with a thin coat of concrete is better than chipping through bed coat and worrying about rust
I would got at the thick areas along the the track gingerly with a wide dull chisel and a hammer (maybe even a large flathead screwdriver if your feeling adventurous). Get most of the high spots, leave a thin white layer. Bed lining with a thin coat of concrete is better than chipping through bed coat and worrying about rust
It’s a truck. Honestly I’d leave it I’ve put a couple dents in my bed and scratched the Bedliner as well. You can always put a piece of plywood in the bed to protect the bed. I really like how that works on mine plus it would cover the concrete.
Remove as much as you can then pressure wash it.
pour a cup of pool acid on it then hose off after a minute or so.
And try to protect the undamaged part next to it with vaseline or wheel bearing grease while doing this; maybe create a vaseline "dam".
And do you mean concrete and not cement? When the Beverly Hillbillies called their pool a "cement pond" they just added to the already-there confusion !
Reactions: vjmvjm and PNWMTB
Vinegar is acetic acid and mild. I think the suggestion of soaking with white vinegar is good. The cement is basic so the acid should help release the bond.
Tt
1 - 20 of 27 Posts
