I completed this mod over the weekend! I’m happy with how it turned out.
The first step was to run a wire from battery positive to my connectors for the always-powered side. I used a 16 AWG wire for this, which should take 15 amps at the distance of the run. Plenty for what I have planned!
(Follow the white drawn-on line to see the path I took. The circle in the upper right is where the firewall breach is, and the square in the lower right is the only place you can actually see the wire in this photo)
I cut up a firewall plate to get my wires in the cab. I had actually already breached this plate once to run a fog light line, so I widened the hole and made a little wire exit area for ease of access. After the wires are run, throw some silicon on there and call it good.
Now that we’re in the cab, I want to show what I wanted to eliminate with this project:
That’s not all that messy at the moment, but as I add planned devices and gadgets it will get much messier.
In the cab, behind the center panel is my ignition-switched power source, the 12v cig lighter. I spliced into that line with a butt connector and wrapped in heat shrink. I’ll have to remember to be more careful when pulling that panel off so that I don’t pull out a wire.
Placement. As mentioned in the OP, I will be putting this near the shifting mechanisms in the space there.
Instead of wood, I used cardboard as my platform. I didn’t have my spare wood handy, and I could always redo later with minimal effort. I screwed it in to help secure it in place.
We are wired! You can see, I have two circuits-- 4x left side for always-on, and two right side for switched; both circuits are fuse protected. In my planned projects, I have more always-powered devices than switched, so this will work for now. I can always change it up later!
Finally, placed where it will reside. It is secured with two dots of velcro. The only thing hooked up right now is fog lights, because I have to re-do the wiring on the steprail lighting before I hook it up. I will likely put in interior floorboard lighting soon now that I have a central ‘base of operations’.
