1 - 10 of 10 Posts
While wiring a light strip to the rear light harness of my 2016 Frontier Pro-4X, I caused a short while squeezing a wire connector to the wire for the rear running lights. I heard the electrical arc sound and then no running lights...in the rear only. The owners manual doesn't show a fuse diagram, at least not listed under fuses in the index. I pulled each and every 10, 15, 20 Amp fuse in the glove box pannel and in both fuse box panels under the hood, looking for a blown fuse. I couldn't find a bad fuse so I figured I must have missed it somehow. I have turn signals and brake lights but no rear running lights and tag light. If you can help I will move you to the top of my xmas list...it would be much appreciated. Thanks Rick
The more that I think about this the more I am thinking it might be a broken wire. Did you check the wiring where you made the crimp? Strip everything clean and rewire using a solder joint?
I found it. It was a fuse that looks good on one side but when you turn it over all you could see was a small spot inside on the filament. Couldn't really see that it was burned into. The battery in my multimeter was dead after years of nonuse so I borrowed my neighbors multimeter and this was the only way I could tell that the fuse was bad. Rick
It'd be a sad state of technology if you could fry your BCM before you blow a fuse since the
fuse is there to protect everything else. So I'd say if it's not that fuse, it's probably a
broken wire as stated above.
My running lights fuse is F7 as in the module below (which, by the way, makes these fuses
rediculously hard to get to).
Thanks Bob. I really appreciate your reply. I checked everything you mentioned. It was one of those bad fuses that was undetectable without a multimeter. I really appreciate you taking the time to offer your help.
Rick
· Super Moderator
Some people have reported having their BCMs fried when they took their truck to Uhaul to have it wired for hauling trailers. I know that a fuse should protect things but they are not perfect. Thanks for helping with your detailed response.
1 - 10 of 10 Posts
