Ok so in the next few months I'm looking to complete my titan swap on my frontier. Soo I just got a question with this.
Anybody figure out what to do to make the rear suspension kinda match with the front. Like I'm going to get 7-10 inches with the titan swap I'm doing with the tundra 1st Gen coilovers I'm doing but I don't want to have 7-10 inches in the front to and not have anything in the rear. I want it to lean a little but I want to be able to run 20 inch rims and 33 inch tires. Any ideas as to what could kinda squat it a little bit so it looks good bit would clear 20s n 33s? Any info helps and if you have done the coil bucket tundra coilovers that gets the 7-10 inches of lift in the front post pictures below I'd like to see how it looks thanks
You are not going to get 7-10" of lift.You will get 7-10" of travel.
2015 Xterra Pro4X
In know this not a Frontier, but it'll help give you an idea. I have the Tundra 5100s with the Moog 81092 springs set on the second notch. I got between 3" and 3.5" of lift. My height measurements were identical between front and rear. I don't want my truck to squat, so I set my PRG shackles at the highest setting. In the back, I have OME springs with the PRG shackles. You should be able to run something similar, but keep the shackles set lower if you want squat.
Sent from my XT1575 using Tapatalk
Oh ok got ya well guess that helps a little ha I didn't think shackles would go up in the height of 7-10 inches but that is wheel travel ha not lift so I guess I'll run shackles. Anybody know with the titan swap can you run 20s n 33s? I know the from would clear but the back I'm worried about
