1 - 4 of 4 Posts
Replacing rear leaf springs. One side went fine. The other side...notch won't line up for the center pin. Anyone else ever have this issue?
TJM XGS heavy duty leaf spring. I'm in talks with them as well. Everything measures the same as the stock. So it should fit.
Sent from my SAMSUNG-SM-G891A using Tapatalk
The axle was free floating and shifted when you unbolted everything you just need to pull the axle a little with a ratchet strap to line it up
Reactions: joshuaglaude
Thank you. I did end up doing that. There's just certain things that just don't cross my mind right away. All turned it great. Just need to re torque the bolts as specified by the springs manufacturer.
Make sure you torque them with the weight on the suspension, not with the vehicle jacked up and suspension hanging.
1 - 4 of 4 Posts
