1 - 20 of 20 Posts
· Super Moderator
I'm on my 5th frontier and have never heard in all that time about these being offered. It would be a good item to have.
I see they offer them for ford and gmc
I am enjoying my new frontier with its clean frame but when winter hits here there will be tons of salt that will get thrown up in there without an inner fender liner.Onebenefit is that I can wash out the salt that gets in there without a liner but I would prefer to have something there to stop some of it .
I spent the entire winter last year looking for something. even tried fitting ones for domestics into the Frontier... not so much... Spraying it out helps... but not alot. Only suggestions I can provide:
Take some thick vinyl and make your own liner... depending on your skill... mine didn't look great...
Before the winter starts, hose it down real good, spray the underside down well with a undercoating or sealcoating...
Anytime, hose it down real good, suit up REAL well in paint-clothes (covering ALL exposed skin & hair) and coat the underside with a frame paint/encapsulant
Chassis saver chassis saver 1 yr later
Eastwood products
Or go to someone like Ziebart and have them treat the truck... ziebart or NH oil undercoating The NH oil undercoating is similar to fluid film or the old timer's pro tip of spraying the truck frame with used oil or atf and then driving down a dusty road.
Eastwood products
Ballpark figure for a Ziebart treatment?
each franchise is independent, you'd have to call them for an estimate. Doing it yourself isn't too difficult, only stuff you have to be careful of is the Chassis Saver encapsulant. That stuff bonds to skin and everything else... its like superglue... Years ago I used Fluidfilm and it does well... alot of folks up north swear by it. spray it on thick, drive dusty roads, then let it dry for a day. you're good for a year or 5. If you don't have dusty roads, just let it set up and remember to retreat every year.
Old thread, I know, but this issue of the lack of fender liners in the rear wheel wells was kind of bothering me as well. There are a lot of crevices in the forward section to trap debris, especially on the driver side with the fuel filler line. So this is what I came up with. I removed the forward "deflector" on the rear wheel well, but kept the bracket. First I made a template with poster board, then I cut it out from a Mohawk plastic boot tray from Target with a diamond plate pattern ($4.99). It's about 30" long so it only covers the front section of the wheel well. The plastic is very similar to the rest of the exterior plastic and cuts easily with metal shears / tin snips. The bottom front attaches with the same 2 screws that held the deflector to the bracket, and for the top edge I used heavy duty outdoor Velcro after cleaning the surface thoroughly ($4.50 at Lowes). Seems to stick really well now, but I'll see how it holds up. Since it attaches to the original deflector bracket it can easily be removed for cleaning out with 2 bolts. So for less than $15 total to do both sides it's a cheap solution.
Floor Automotive exterior Carbon Flooring
Tire Automotive tire Synthetic rubber Wheel Auto part
Tire Automotive tire Footwear Auto part Synthetic rubber
Automotive exterior Auto part Exhaust system Vehicle Muffler
RDP, Target has a larger version of this same boot tray ( 3' 3" long ) for $9.99 each, I think I'm going to co-opt your idea and cut me out a pair as well. Thx for sharing.
Reactions: RobFrisco415
are these kinda what you are talking about?
I made mine to cover the front curved part of the wheel well, especially on the driver’s side where the fuel filler tube is. Those rough country ones cover the flat part against the frame, and helps cover some bigger gaps that show with a body lift.
Cool. Post some pics.
Video will be posted tomorrow on my Frontier Geek YouTube channel. I'll post direct link here, when it's up.
Reactions: Produceman007
As promised, here's the video.
Right now, tension, the plastic's trying to straighten, the liner is bent. I'm considering adding a few small stainless steel screws at the trailing edge, probably will.
Eastwood products
I have been using NHOil for 3 yrs now and love it. Fluid film doesn’t stand a. A chance against NhOil. I had their Boss Wax sprayed on my wife’s new suv.
2007 Nissan Frontier NISMO CC
FYI, this material is pretty hard PLASTIC, not rubbery at all - wouldn't think this material would last very long. Better to use something more flexible and forgiving.
Mine are still in place and still working just fine, forgiving or not, they've been pummeled by hard gravel roads and come back for more.
Reactions: shift_RUSH
1 - 20 of 20 Posts
