1 - 9 of 9 Posts
Hey guys I have a 2005 frontier nismo with 180k miles. A couple of weeks ago the rear diff was working fine. Got in a spot that I needed it, hit the button. It flashed three times and went away. After that it wont even flash until I turn the truck off and back on and it still only blinks three times. Any advice? Thanks!
-JP
Have you done any other diagnostics? Have you checked the wiring and fuses? How fresh is your differential fluid? Has it ever had water in the diff?
I hit a branch the other day and ripped off the ground strap on my catalytic converter. It's possible you broke a wire.
So after a little more digging, I found that my rear diff lock is aftermarket and I did not install it. Ive been able to lock the diff in 2wd, 4wd high and low. I thought this was standard until I had this issue and need a new connector. The wire split so close to the connector on the diff I cant splice it. Looks like I need a new connector but the problem is I am not sure what aftermarket company it came from. Does anyone have any ideas? I can see the stock connector right about the one mine is hooked up too. I can add pictures later if anyone would like. Thanks in advance
Someone probably did the anytime e locker mod. The connection and the diff is the same as factory with all the wiring changes made behind the dash.
If you know how to de-pin a connector you may be able to salvage the one you have. If not I'd look around at some junkyards.
1 - 9 of 9 Posts
