1 - 15 of 15 Posts
Since i got my 15 Pro-4x, i have seen many people talk about doing the extended breath line for the rear diff. It seems every time i read about this, the person down the line has either a leaking diff or blown seals on it. Could it just be a coincidence or not?
What are everyones suggestions on this? i am not a person who submerges my diffs every week, but i am also not wanting to have a situation where my diff sucks in muddy water.
Is it worth it?
Absolutely worth it. Most of those complaining probably had already done the damage beforehand due to a clogged vent. Most people do not have issues (myself included). The earlier you do it the better. I did mine around 30k miles, I'm now close to 90k without any leaking.
ive had mine done for about 60k miles. and i had my axle apart about 30k miles ago and i do now have a leak on my passenger side. its only a small amount of residue, but its still there.
i would say it helps for sure, but seals and bearings can and do go out.
i am sitting on 30k miles right now and no problems, i just do not want to speed up the process of having those replaced. Thinking about waiting until warranty is over to do it. or not. not so sure...
It is just another poor design by Nissan that they never corrected.
Just did mine today. I'm at ~19k miles.
Did mine at 800 miles... We'll know eventually if it made a difference. Been puddle jumping some flooded roads around here lately. Glad I got the stock axle vents extended above the water line...
Most people just bought the parts and did it themselves.
The kits are probably pretty much the same.
I used AN fittings,-08 stainless braided line and a crank breather filter. Overkill except for extreme usage.
Reactions: NYCe_Frontier
You don't even need a new fitting, I just ripped off the top of the current one with a flat head, pulled the spring and plunger out, and then put the hose over the lip that was left. Then just clamp it on with a hose clamp. Total cost is less than $10, no need to buy the overpriced PRG kit...
This is true. The barb fitting I used had a nice inch or so long barb to slip the hose on to. I wasn't all the way confident on the length of the fitting as Glamisdude did, but, I tend to overthink things. I think the fitting was like $6.
Isn't there a toyota part # too? Seems like i read that it's a better fitting?
there is, though I used the Nissan one. Screwed right in place of the OEM one way valve.
Discussion Starter · #15 ·
I have not seen that one, i saw an ARB one that was for a toyota and it was pretty nice. Combined all 3 breathers in one. Front and rear diffs a well as transfer case. Those sit high enough so would only do the rear. But its too expensive.
1 - 15 of 15 Posts
