Recently I did a fluid change on my c200. I did it in my garage, on level ground, and no ramps. Drained the diff and all was good with no metal chunks etc.
My issue was that I only got about 1.5 quarts of fluid back in. I believe it called for a hair over 2 quarts. The fluid poured out the fill hole so I know it was full at the time.
So what gives?
Has anyone else noticed the c200 doesn't take as much fluid, or do I need to recheck the level soon to see if maybe there were some large air bubbles or something?
I haven't noticed any leaks or weird actions in the back end, and all feels good. I know that's not what I need to think, but it's been bothering me for a while now wondering what's going on.
Sent from my XT1585 using Tapatalk
I found a copy of the FSM online, and here's what I gathered for the fluid requirements:
1 Quart Front Gear Oil (GL-5 Spec 80w-90 Synthetic)
2 Quart Rear Gear Oil For C200 Differential (GL-5 Spec 70w-90 Synthetic) )
FSM says, "C200 1.6 liters, or 3 3/8 pt (US measuerment), or 2 7/8 pt (imperial)"
at 1.5 qts, only 6 ounces shy of bone dry fill - usually few ounces left in diff after drain.
If 'praying on your mind', open fill plug and try to add little more.
