As luck would have it, while in a store when out of town I cam out to find someone had backed into the right rear of the bumper. It is beyond repair and I am looking at my options. I was a little concerned when I saw the amount of damage to the bumper, did not see it happen but the alarm did not go off. So should I replace it with OEM or find a more rugged solution that wont break the bank. Any suggestions?
thank you
Before you decide on the rear bumper, think about the front. If you ever thing you will replace it, ask yourself if you want the front and rear to match (same manufacturer) or if you are okay if they don't. Example would be an IB rear and a shrock front. One is more angled then the other so I am not sure if you will be turned off from it or not.
