1 - 7 of 7 Posts
Are there any writeups on rear block install instructions?
If not, could someone please help type some detailed instructions for me???
I just sold my 2" rear blocks and have no instructions to give the guy..
Thank you
*Search didn't come up with anything...
if he needs instructions to install blocks then he should not be doing it to begin with
Just type up a sheet stating what you did.
Place wheel chucks behind front wheels.
Jack up rear end and support frame with jack-stands
Remove U-bolts
Place spacers inbetween axle and leafs.
Install new U-bolts.
Torque to spec and remove jack-stands.
Remove wheel chucks.
Check one last time on bolts and give it a test drive.
makes no difference to me.....just trying to complete the sale
haha I got ya, call Greg at PRG and see if he has his in PDF or something
cool...thanks fellas...I just figured if there was something semi-official floating around out here on the board it would be an easy solution and the guy I sold them to (my neighbor) would feel a little more confident. He's far from a mechanic but I don't hold that against him, because neither am I..
thanks again
I just typed up my own...I forget though....does the bolt under the bump stop need to be removed?
The stock u bolts get torqued to about 55ft. lbs and Greg says the PRG one I have are one size bigger and one grade better so I torqued them to 60ft. lbs. per what info I found online. If this doesn't sound right let me know. What I really need to know is how many miles until I need to recheck them and how many times do I have to do that before I can call them good?
1 - 7 of 7 Posts
