1 - 20 of 20 Posts
I've got a 4cyl 2wd truck. I plan on launching a boat one time this weekend, so the rear axle is going to be submerged.
Is the stock little vent cap a 1-way valve or or is it like a chimney and just has a up/down airflow path?
Only concerned about water when the axle is submerged and whether the stock setup will let water in for 1-2 submersions.
I did see threads about relocating the breather with a hose up to the frame. I'm not in dusty conditions, so I wouldn't do it for that reason alone.
Thanks.
Edit: I just looked at the axle and I can't find a vent or hole of any kind on it. Is this axle sealed?
Edit2: Doh, checked the FSM and it's along the axle tube on the right side. I see it now.
The factory vent has a spring loaded cap held up (open) by a very light spring. It seems that the cap would remain open under normal circumstances. If there were an air vacuum that closes the vent (or the vent becomes plugged) it is thought that it puts undue pressure on the axle seals and may cause premature failure. Jury is still out on that.
For me, given that the vent is normally open, I did not want to take the chance that water, snow, or ice could impact the operation of the vent, or water being able to enter the axle when ramping a boat or traversing high water. I did the vent mod and extended the axle vent to an air filter installed in the passenger tail light area. Figure if I have water at that level, I have a bigger issue than the axle.
If it were me, I would do something to extend the vent above the waterline.
You can also use a toyota part number as well, i don't remember it but there is a how to on this site. Review and i believe it has that number in it. It was in stock for me.
You don't even need the barb fitting. Once you take the cap off and remove the spring and plunger there is enough for a hose and clamp to grab. This is how mine has been for over 3 years without issue. Just head to autozone and get about 5 feet of hose, cheap fuel filter, and 2 hose clamps. Cost is less than $10 and takes no more than 15mins to do.
I prefer a barbed fitting as less chance of the hose coming off.
Discussion Starter · #15 · (Edited)
Ok, got it installed. Yes the threads are the same for both axles.
Nissan part #38323-C601A - $7.84
20' of 3/16 ID hose from Home Depot - $5.36
Zip ties - already in stock
As you can see, the fitting is definitely tapered and not a "straight 1/8" thread" as I've seen stated a few places. I applied a wrap of pipe tape and threaded it in.
Gone but not forgotten Member
I launched my boat where there were no launch ramps.I would release enough winch line to allow for the boat to slide almost half way off the trailer. To do this I would go hard in reverse and slam on the brakes.Had to do it a few times.Some of my friends made extended hitches just for launching also.Saved a lot of brakes from the salt water.
Discussion Starter · #18 ·
For ocean going that absolutely makes sense.
I'm launching in fresh water so I'm not as concerned. I do need to back in fairly far as I have a stand up in the bed and not on a trailer or hitch hauler.
1 - 20 of 20 Posts
