1 - 15 of 15 Posts
when getting wider sized tire is there a need for a new rim size in order to accomidate?
example: the tire i have right now are 30inch by 9.50s and im wanting to go with something like a 31 or 32 by like 11.50 ish.
sorry for the stupid quetion but this is how i learn:(
bump
if they are stockers i would thin so, but it would also depend in the wheel backspacing.
without extra lift or proper backspacing, you would probably have to do some trimming
assuming clearance isnt an issue, I think you can go 4" wider than the rim. though i have seen some go a little wider.
Tire manufactures usually have the rim width listed with the various tire sizes on their web site.
That being said, I ran a 31X10.50 on a 15X7 wheel. And I recently upgraded from a 265/75-16 to a 285/75-16 on my stock 16X7 NISMO wheels, with the 265 being ~10.4" wide and the 285 being ~11.2" wide. The 11.2 on a 7" wheel probably isn't recommended by the tire manufacturer, but there are many on here with that setup and no issues. I reduced the air pressure to get even tire/ground contact across the width of the tire. Otherwise, you may see uneven tread wear.
Discussion Starter #6
well yall yet again you have blessed me with your abundance of knowledge!!!!!!!!!!
THANK YOU!!!!
Discussion Starter #8
what would be a really thin/skinny 33in tire?
WELL I DONT REALLY KNO BUT MINE ARE 9 AND A HALFS AND TO ME THEY LOOK REALLLLLY SKINNEY EVEN WITH ONLY 30 INCHERS.... SO THATS PROBABLY SMALL IF THEY MAKE 33S THAT SKINNY
Discussion Starter #10
cool thanks! but how do you know how tall a tire is by the codes on the tire?
WELL I DONT KNO MUCH ABOUT TIRES
BUT WHAT I DID WAS COPIED WHAT IT SAID AND THE TYPED INTO GOOGLE "(WHATEVER YOU COPPIED) IN INCHES"
AND BY THAT I HAVE VOME TO BE ABLE TO KNO WHAT SIZES MOST ARE
DO U NEED HELP FIGURING OUT WHAT SIZE ONE IS?
well like i have a prg 3in lift, and i am supposedly able to clear 33's vertically... however many 33's are too wide so that when you turn you get rubbing. My question was do they make a 33 that is narrow enought not to cause this issue
ill google it or just go ask at the tire shop
Discussion Starter #12
HERE IS WHAT I FOUND FOR THE BFG ALL TERAIN
33X9.50R15/C
THATS A REEEEALLLLY SKINNEY TIRE LIKE COOKIE CUTTER
HA HERES THE SITE FOR THAT
BFGoodrich Tires | Error
Discussion Starter #14
1 - 15 of 15 Posts
