Rattle/noise from front passenger side
6.2K views 4 replies 5 participants last post by  walk_in_woods
Take a rubber mallet and tap on things starting with the exhaust system, it doesn’t need to be hard and things that are loose like a heat shield etc are easily discovered. You can tap the floorboards, suspension and it may quickly appear. I once had a plastic clip on my firewall create a buzz at a certain rpm range and all it needed was to be removed, a dab of silicone added and put back in place so it was now adhered at cushioned and never made a sound again. It can also be a wire or harness or a cable lightly contacting something, it’s that simple.
Hope this helps you discover the cause.
