1 - 1 of 1 Posts
I was doing a search on axle wrap fixes and this came up. Sounds too good to be true.....is it snake oil?
check out Roadmaster Active Suspension, rear leaf spring suspension, simple installation, improve road handling, reduce sway, reduce dangerous body roll on cornering, eliminate bottoming out, eliminate wheel hop, eliminate axle wrap, strengthen the rear leaf s
They claim: Less body roll, eliminates axle wrap, and doesn't change the ride.
Looks easy to install.
I just can't believe it's true. They have the 05-09 X listed so it look like it is available for 2nd gen.
What do you think?
I can't see this working as good as a traction bar.
wow, really? Thats what I thought too.
1 - 1 of 1 Posts
