81 - 100 of 911 Posts
Discussion Starter #82
Awesome work! WHat is your plan for FM radio reception? I assume with the nifty head unit, you never really use FM?
Originally I was going to look into getting one of those hidden antennas (the kind that you stick on the windshield) but then I realized that I stream like 80% of the time (Apple Music, Spotify) and if not then the other 20% of the time I listen to XM - so I didn't bother with the FM anymore.
Just read your entire post. Excellent work and love the attention to detail. I like OEM style modifications. Your knowledge of crossovers, amps is excellent but some of it went over my head. Can you educate me what was the purpose of installing mini dsp (digital signal processor?) so you can feed each speaker without going through passive crossover and separate high mid and low-range frequencies?
super pumped you did this antenna mod. ive been looking into something like this as well but hadnt even thought of swapping the two.
i stream pandora 99% of the time so i dont mind loosing it as well.
Discussion Starter #85 (Edited)
Brace yourself - this is a long answer hahaha:
Basically it's more control over what, where, and (bonus) when the audio signal goes to the speakers. Initially without the miniDSP, my setup (and the common way to do components) was like this:
EXAMPLE 1: Typical Component Install w/Passive Crossovers
Front-Left head unit ch.1 output goes to:
-> amp input ch.1 -> amp output ch.1 -> left passive x-over -> split signal to both left tweeter and mid-range speakers
Front-Right head unit ch.2 output goes to:
-> amplifier ch.2 -> amp output ch.2 -> right passive x-over -> split signal to both right tweeter and mid-range speakers
*Pretend I have a basic head unit in the example to keep it simple
So each front channel is full range, gets amplified full range, goes into the passive crossovers at full range, and only then does the passive crossover split the signal: high freq. to twtter, low freq. to midrange. Basic component install, right? It's simple, and a majority of the time it will satisfy most, but this method has limitations.
Limitation 1 = passive crossovers generally have preset crossover points, so if they do not match the frequency range of your speaker, then you have to just select what's "close enough"
Limitation 2 = passive crossovers are "passive" - signal strength/power is lost as it passes through the passive crossover, before it gets to your speakers.
Limitation 3 = no time delay
Having the miniDSP in place of the passive crossovers lets me do a lot more with the sound; with the miniDSP I have practically infinite crossover points (eliminates limitation #1), since it's an active setup now, no signal loss (eliminates limitation #2), I can digitally delay the time it takes for the signal to reach the speaker (eliminates limitation #3)... and because it is now an "active" system, the layout becomes this:
EXAMPLE 2: Component Install w/ACTIVE DSP
-> miniDSP input ch. 1 -> miniDSP output ch.1 -> amplifier ch.1 -> direct to left mid-range speaker only, and
-> miniDSP input ch. 1 -> miniDSP output ch.2 -> amplifier ch.2 -> direct to left tweeter speaker only
-> miniDSP input ch. 2 -> miniDSP output ch.3 -> amplifier ch.3 -> direct to left mid-range speaker only, and
-> miniDSP input ch. 2 -> miniDSP output ch.4 -> amplifier ch.4 -> direct to left tweeter speaker only
See the difference? basically each speaker is isolated by the miniDSP, so each speaker gets a direct signal from the amplifier (no passive crossover loss), and at the same time the miniDSP gives me full digital control for each speaker independently:
- independent crossover points; high-pass, low-pass, or combination of both,
- independent input and output level adjustment
- independent time delay
- independent parametric equalizer
So with the miniDSP I am no longer limited by preset passive crossovers, AND I gain the added ability to shape the sound exactly to my liking (before amplification where it's the cleanest signal) using the extra features like time delay and parametric EQ.
However, obviously more features/more options = more complicated installation and it takes A LOT more time to setup, plus the primary danger of an active system (among other things) is that you can easily blow a speaker out if you get a setting wrong.
But hey, thanks to (hours and hours of) fine tuning it sounds like the singer is literally sitting on top of the dashboard, dead center, with the rest of the band on the hood when I close my eyes and listen to music
::wink::::grin::
Side note: my Kenwood head unit has some of these features built-in, but it's more time consuming to adjust compared to plugging the miniDSP into my laptop and being able to make changes on the fly while the stereo is playing
It sort of all started because I didn't want an extra long antenna placed somewhere random on the truck. It reminds me of my old RC cars.
EDIT: wait a bit, there's a part 2 to the antenna install you'll want to read if you're considering taking on the mod.
Discussion Starter #90
Raine: thanks very much for explanation. This is how music should be listened to.
No prob... I'm not super expert level but car/truck audio is one of those things I always enjoy, whether it's coming up with a component list for friends, or messing with the tuning, etc.
Interested on part 2. While I am NOT removing the FM antenna, that gives me thoughts on doing similar on the driver's side for a CB antenna. I'm also one who pays probably way too much attention to how things will look but at the same time require things to function to their best.
I didn't notice the driver's side area, but keep in mind that I used the OEM mounting points for the antenna on the right side when I bolted my new mount in (I failed to specify that in the post)... whether or not the driver's side has the same holes, I'm not sure off hand.
I've also noticed that in stock form, the Frontier is quite capable. Once you lift it 2" though, you'd be amazed at the number of rocks that you can clear under you.
hopefully soon I'll understand that feeling haha
I'm sure there is nothing there, but, carrying the idea to the driver's side would not be too difficult.
Great looking truck! Where did you get the Navara badge? I got one but one of the letters got really scratched up. Plus all my letters are separate.
Discussion Starter #94
Just caught up on your progress. I love the thought and time you put into everything you touch on your truck. It's coming along great.
Thank you sir
Found it being sold on eBay from a Nissan dealer in Thailand, so it came in a Nissan parts bag (just like if you bought it direct from the dealer here) complete with the blue alignment foam and clear top layer to make install easy.
Raine: Where in the cab have you installed your CB. i have cobra 29xl but there is no suitable place to install it. Can you share some pictures?
Discussion Starter #97
Post #78.
I have a Midland 75-822, it doesn't have an outboard control unit like the Cobra 29XL (part of the reason why I bought it):
https://midlandusa.com/product/75-822cb-radio/
I was considering a Uniden Bearcat 680 (which does have a control unit)... if I got that I planned on putting it somewhere under the glove box
Ah thank you,. I initially thought that was just to microphone! thanks. Someone here a while back installed a CB just behind the center console in a custom made box and it was nicely done but cannot find it. The Cobra has the LCD screen with different background color options, one of them is fairly close to the amber illumination in our trucks. I got all the bed LEDs today so I will install those this weekend with magnetic switch function. Hopefully it turns out good.
I'm thinking this may be minitruckin?
Sorry for thread-drift.
