681 - 700 of 884 Posts
Hi Raine, I just installed my new king coilovers yesterday. Can you tell me how much you ended up tightening that collar down from its factory setting? I brought mine down about an inch and a half but I'm wondering if that's too much.
Thanks
Discussion Starter #682
Posted this in the "what you did to your truck" thread, thought I'd add it here too...
Been testing something since last Tuesday... but what? ::grin::
Discussion Starter #684 (Edited)
Thanks
If you're preloading an inch and a half, you need a different (stiffer or longer) spring. That's too much IMO.
Why are you preloading that much? Are you running King #25001-111 coilovers?
New OEM mount CB Antenna?
nope, that's still the same as before
Why are you preloading that much? Are you running King #25001-111 ?
Yes, thats the model number. I just wasn't sure how much if any it would need preloaded to get about 3" of lift up front. The friend helping me install thought it needed more, but I'm seeing that it's robbed me of a lot of travel. I thought you said you dialed yours down a bit after putting them on the truck. Just wondering if you knew how much?
Thanks!
Discussion Starter #688 (Edited)
Thanks!
Well that explains it... I don't have off-the-shelf Kings.
FYI more info on the #25001-111's:
  • #25001-111 is one of their "OEM" coilovers
  • They run a 500-lbs. spring rate, slightly higher than OEM
  • They have the same travel as OEM shocks
  • They are designed for up to a 2" lift
  • Anything above 2" may degrade the setup (i.e. too much pre-load).
I would guess some type of clear bra or some windshield wipers.
Try looking "farther in" :😉:
- #25001-111 is one of their "OEM Performance" coilovers
- They run a 500-lbs. spring rate, slightly higher than OM
- They have the same travel as OEM shocks
- They are designed for up to a 2" lift
- Anything above 2" may degrade the setup (i.e. too much pre-load).
Try looking "farther in" ::wink::
Ah tweeters.
Discussion Starter #691
winner winner chicken dinner
Are you relocating your HSK tweets...or did you upgrade to Mille/other perhaps? Or, might they be mids?
Fwiw, I just checked Hertz website and didn't see the Hi Energy lineup at all. Kaput?
Discussion Starter #694
The Hi-Energy line was discontinued it seems.
Not changing to Mille's, don't feel like I need to. What I'm trying is a new position for the dash tweeters, having them fire straight up to bounce off the windshield spreads the sound but kills any distinct directionality.
How improved is directionality w/ new location? Are those pods or what?
My A-pillar location works...will say they are a bit bright, but 'equalizable'.
Discussion Starter #696
They're pods, not quite finished yet so I haven't posted about them in detail. And yes, the idea was to get more directional sound aimed not at the windshield but at the driver/front passenger's ear level.
I thought about the A-pillar method but I wanted the tweeters to have enough angle to aim inward towards the cabin, the mounting cups that came with my tweeters had a shallow angle, and would only aim at the opposite side windows... with the custom pods the tweeters point the sound more towards the driver/passenger ear level, and slightly higher than ear level to bring the stage above the dash.
Preliminary testing sounded really good, took some new measurements to correct the time alignment with the new positioning. I'm at the last step of finishing the pods, but it's been difficult to find a matching cloth or paint. Nissan "steel" gray isn't gray at all, it has some small amount of blue hue in it. Also I still need to do some more sanding to get the shapes as smooth and as symmetrical as possible.
Once I get them finished up I 'll be posting the whole process here.
Cool, looking forward to your end product review.
What is your high pass/tweeter crossover freq...or preferred freq range since you're active?
Discussion Starter #698
Right now I am actually band-passing the front tweeters between 3.6k-20k to try to smooth out the higher frequencies... the Hertz tweeters are generally bright so I'm using a shallow 12db roll-off up top to counteract that. I have the lower crossover point at a super steep 48db slope to eliminate as much gap between the tweeters and the midranges (midrange is crossed up top at the same [email protected]).
Discussion Starter #699 (Edited)
The 'Took Forever' Tweeter Pod Project, Part 1 (06.09.18)
So a couple months ago I finally got around to working on a project I'd had in my mind for quite some time now - custom front tweeter pods for my Hertz HT-25 tweeters. They already sounded great, but I wasn't 100% happy with the stock dash locations due to the fact that it aimed the dash speakers (or tweeters, since I was running components) up toward the windshield. Sure, it made the sound bounce and spread towards the cabin which was by design but when it came to distinct left/right separation it wasn't as "pinpoint accurate" as I was looking for. The solution was to figure out how to aim the tweeters towards the cabin where the sound would have a direct shot to the listeners (instead of bouncing off glass first).
Hertz HT-25’s in the OEM dash location and position.
I thought about flush mounting the tweeters into the A-pillar but that would only bring the tweeters out of the dash. They would be still be aiming towards each other, not directly towards the cabin. Also, this might be a little odd but it would bother me that I'd have dash speaker grills with no speakers underneath them. The solution I came up with was to fab up some custom tweeter pods that would elevate and aim the tweeters from the factory dash location. I already had a pair of extra dash grilles so the plan was to build custom fiberglass pods using the dash grilles as a base and the Hertz surface mounts (included with my Hertz HSK-165 6.5" Components) to create a pod that would literally snap into place where the OEM dash grill is.
Oh, by the way: I’ve never done custom fiberglass before. Yikes!
Right... so instead of whining about it on a forum (LOL) I decided to teach myself/learn how to make my own fiberglass tweeter pods. I did the research with online tutorials, I watched countless YouTube videos and have seen 423,244,090 different ways a speaker pod is made, and then I jumped right in. To be honest I pretty much already had a good idea of the steps that were involved; a lot of the “prep/research” time was picking the right chemicals as I didn’t want to use any cheap stuff for something I knew I was going to spend some time and labor on. Here’s what the “parts” list for this project ended up looking like:
- 2x Hertz HT-25 tweeters (included with component system)
  • 2x Hertz HT-25 surface mount cups (included with component system)
  • 2x OEM Nissan Frontier dash speaker grilles ($20)
  • Evercoat 499 Fiberglass Resin, 1-qt. ($35)
  • Evercoat 911 Sea Glass fiberglass cloth ($16)
  • Evercoat 425 Metal Glaze Ultra, 30-oz. ($35)
  • Evercoat 360 Cream Hardener ($5)
  • SEM High Build Primer, 16 oz. ($22)
  • SEM Low Luster Clear Color Coat, 12 oz. ($16)
  • Bottle of CA glue ($5)
  • 3M Sanding Sponges in 60/180/220-grit ($12)
  • 3M Pro Grade Sandpaper, 440-grit Extra-fine ($4)
  • 3M Liquid Resin Hardener ($3)*
  • Custom mixed SEM Color Kit paint from a painting buddy (free)
  • Old pair of the girlfriend’s pantyhose (free, duh)
  • Water spray bottle
  • Some metal sanding files I already had, gloves, etc.
*only bought this because I misplaced the hardener that came with the Evercoat resin
A lot of the stuff above I already had, I mainly had to buy the resin/body filler stuff and the paints. So here we go… but first I had to make a small mod to the HT-25 tweeters. Since I knew I was going to be removing/reinstalling the tweeters numerous times during this project I went ahead and soldered in some small connectors on the tweeter leads to allow me to quickly plug and unplug them when needed:
Soldered and shrink wrapped plugs.
Next, with some guesswork (as far as positioning) I started experimenting with the angle and location of the tweeters. Using the Hertz surface mount cups, I used a simple bolt and locknut to attach them to the dash grilles. This way I could rotate the cups easily while trying to find the right angle for the tweeters. From here I temporarily stopped working on the project because I wanted to take the next few days just driving around, listening to music as I usually do, and experimenting with the direction of the tweeters.
Trying to find the right angle.
Note how I tried a few different mounting points.
A few days? Fast forward about 21 days! During the experimental period I ended up repositioning the mounting bolt 3 times, and adjusting the angle of the tweeter cups countless times, until one day I thought to myself “hey, I think that sounds pretty good” - so 3 weeks later I continued the build. The next step was to secure the mounting cups exactly at the position and angle I was happy with. This was as easy as using my hot glue gun:
Hot glue is pretty strong stuff.
I didn’t care what the glue looked like because I already knew it would be covered anyways by the fiberglass shell. To start the shell I used an old pair of pantyhose donated by the girlfriend (yes, I asked):
She doesn’t use this color anymore on airplanes.
Since my design had a concave section to it I couldn’t just stretch the hosing over the whole thing and call it a day; to get the front part to curve from the bottom of the tweeter cups, I started by sticking the hose to the outer rim of the tweeter mounting hole using CA glue:
First the tweeter ring…
…and then the perimeter.
Starting to take shape now.
…followed by stretching the hose around the base of the pod (the OEM dash grille) and also gluing the edges in place with CA glue. With this step done I had the basic shape of my tweeter pods set.
Next it was time to form the solid shell of the pod, so I coated all of the panty hose (except the part where the tweeter would go) with one layer of Evercoat 499 Resin. Remember how I said I’ve never worked with resin/fiberglass before? It’s a good thing I used an old cupcake tray to mix the resin, because it took a couple tries to get the mixture of resin and hardener just right (the first batch went solid in like 30 seconds... ooops!):
So it turns out that mixing resin and hardener is a science.
First layer of resin applied.
After allowing the first layer to dry I did a second layer - but this time I laid down some fiberglass cloth to add more strength. My fiberglass cloth laying technique was super newb, but I made sure to have total coverage. After the second layer dried I put a third layer of resin on for good measure and left the pods on my workbench overnight to ensure that all of the resin was dry.
Have you done this before? Me: yeah, sure buddy.
The next day I trimmed the excess around the perimeter and took a look at my work so far. The mounting cups were secure and in position. The 3 layers of resin was enough for a strong pod. Both pods were starting to take form... however, I only did a fair job laying down the fiberglass cloth (first time, remember!). After the resin dried, the outer surfaces of the pods had a lot of bumps and stray fiberglass strands that required lots of sanding in order to get the smooth, curved shape back.
Could be better, but not that bad.
So YAY - here’s where the hard labor began...
Continued in Part 2, here.
Good work. IMO...I don't think anyone gets the mix right on their 1st attempt working with resin. The resin is amazingly strong. Your pods should be nearly indestructible and last a lifetime.
About this Discussion
135 Participants
dadfish
Nissan Frontier Forum
Welcome to our Nissan Frontier Forum! A premier community to share your mods and builds. Chat with like-minded Frontier owners.
Full Forum Listing
