641 - 660 of 909 Posts
I spent way too long reading this thread. I’ve definitely gotten a lotta ideas for subtle things I’d like to start with like the red tow hooks. One unique thing I’m trying to do is figure out some type of rack I can use to hold my ladders and conduit I carry with me since this is a work truck, but will still look good like the off road style bed racks and roof racks I see on other peoples trucks. Any input or ideas would be appreciated. A topper would be perfect, but I’m not about to spend $2k+ on one. Maybe a tannou cover that would work with a rack? I haven’t had much luck on here finding solutions but you seem creative
I've never seen someone with a tonneau and a cargo rack... because the cargo rack has to bolt to the bedside tops, and that's where tonneau's also attach.
Raine, gotta say I agree about your write ups. Hell they are so good I can't imagine a YouTube video doing justice to the write up!
Thanks... writing vs. video has way different requirements, I write this stuff when I can squeeze some free time out of the day. We used to do writing and video at a previous job and video is very time consuming.
Do you like the TruXedo cover? I was thinking about yours or the x15. Doesn’t seem like much of a difference between the two
Discussion Starter #643
I like my LoPro. The actual cover on my LoPro is a solid vinyl-type material, and water doesn't penetrate it - I've seen a pond or two on top when it was raining, LOL. Also, it hasn't faded (like I would think cloth would) and I've had the cover for years now. Maintenance-wise I just wipe it down with some vinyl cleaner once a month or so.
The X15 I believe is a cloth-type cover. No clue how it handles rain, if it repels it or absorbs it.
I think the cheapest way is one of the racks designed for over a cap, but some are made for covers specifically...
Google image search, "truck bed cover and rack" and you will see some versions. Or, "truck cap lumber racks"
I think I found a picture of the basic concept...https://www.google.com/search?q=truck+cap+lumber+racks&client=opera&hs=6p2&source=lnms&tbm=isch&sa=X&ved=0ahUKEwinquWl-KvaAhVD6YMKHZXHB3wQ_AUICygC&biw=1560&bih=787#imgrc=ih8O9YdTq1ap7M:
And https://www.google.com/search?q=truck+bed+cover+and+rack&client=opera&hs=qEi&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjJqfGd-avaAhVK7YMKHYR9BtMQ_AUICygC&biw=1560&bih=787#imgdii=UOmoTfVAm_2XGM:&imgrc=trbYESu80o2WlM:
I too have been reading along, so much impressive stuff.
I literally have no comprehension of most of what you say in your audio posts but I respect the cleanliness and the detail with which you have it all laid out. Plus there is a NES in that b!tch.
Discussion Starter #650
Thanks for the compliments
How would you comprehend if you never ask me anything? LOL
I only seek answers to the questions that I somewhat know the answers to. For example, I am tempted to buy your amp from you, but it would be an extremely nice paperweight for a while as I figured out what the hell to do with it. I have no idea what I'm doing and I wouldn't pester you with questions on how to connect it. I would probably go back thru your thread.
Discussion Starter #652
I don't mind questions from people who actually want to learn something - not looking for a handout because they don't want to at least try first.
The Kenwood amp would be perfect for those who insist on keeping the stock head unit but want to install aftermarket speakers and need a little more power for them. The Kenwood puts out 75-watts x 4 channels so it is a noticeable upgrade over the OEM (to give you an idea of the difference, bear in mind that the OEM Nissan speakers are rated for just 3-watts!). Pair this amp with say, a set of decent, name brand aftermarket speakers from Kenwood/Alpine/Polk/Pioneer/etc. and you'll get an improvement. It won't be as good as changing the head unit out, but it will definitely be louder than stock.
Discussion Starter #654 (Edited)
So I think I’m going to order some of these components for the front and a small amp to power them. Will the tweeters got in the stock location you think? And do you think it’s worth replacing the rear speakers and powering them or is it more work than it’s really worth to power them?
1. Looks like your budget for the front components is about $150, at that price point why stick with 5-1/4" when you can get a larger mid-range in the 6-1/2" or even 6x9" size? Examples (using Crutchfield pricing, eBay may be cheaper):
Polk Audio DB 6502 DB+ Series 6-1/2" component speaker system, $119.99
Morel Maximo 6, 6-1/2" component speaker system, $149.99
Alpine S-S69C, 6"x9" component speaker system, $149.99
2. Front install notes:
  • If you go with anything other than 6x9" you'll need adapter plates for the doors, such as Scosche SA-69.
  • If you don't want to cut your factory speaker connectors off, you'll also need Metra 72-7401 harnesses.
  • Practically any tweeter 2.75" or smaller in diameter will fit in the upper dash locations
  • You might have have to make an adapter plate to mount the tweeters, here's an example of my Image Dynamics tweeters:
- Some components come with their own adapters that can be configured to fit, here's an example of when I installed my Hertz tweeters:
For all of the above, I'd recommend a small amp that's pushing anywhere from 75-150-watts/channel.
3. As for the rear doors, it all depends on if you want rear passengers to enjoy general music as well. If it's just you and shotgun then you don't "have" to upgrade the rear speakers; in fact ideally you may want to unplug them if you want better sound quality.
- If you go with anything other than 6x9" you'll need adapter plates for the doors, such as Scosche SA-69.
- If you don't want to cut your factory speaker connectors off, you'll also need Metra 72-7401 harnesses.
- Practically any tweeter 2.75" or smaller in diameter will fit in the upper dash locations
- You might have have to make an adapter plate to mount the tweeters, here's an example of my Image Dynamics tweeters:
Word. I appreciate the advice. I will def go with 6x9’s. I hadn’t done much research so I just plugged my frontier into crutchfield and all the recommendations for the fronts were 5-1/4 and 6.5’s. I’m glad the holes are 6x9. I plan to eventually put a prefab box with a couple tens under the backseat so I’ll have some bass. It’s me and my tools 90% of the time so I’ll prolly just the leave the rears alone. Does a dsp make a big difference with the factory head unit?
Discussion Starter #656
Honestly - nothing will make a big difference with the OEM head unit in our trucks; the OEM head unit is designed to cut the high and low frequencies when you turn the volume knob up. So when you have the volume up you're not really getting the full range of frequencies, since the stock head unit progressively "cuts" the highs and the lows in order to protect the factory speakers from blowing out. So realistically upgrading just the speakers only (with the OEM head unit) will result in a slight improvement in volume level and sound quality WITHIN that limited range the OEM head unit is sending out... but you're not getting the most out of your aftermarket speakers' capabilities.
That's why I always tell people on the forum that everything starts with the source - even a basic $99 aftermarket head unit will output the full range of frequencies. Many people try to just do a "speaker and amp" route because they fear losing OEM head unit features such as Bluetooth, backup camera, and steering wheel controls. But the fact is, you can retain those features with an aftermarket head unit - there's every harness/adapter needed readily available to integrate an aftermarket head unit to the OEM features above.
Adding a DSP will mainly let you balance speaker output levels, route exact frequencies to each speaker location, and get the time alignment correct... but again: if you're not feeding the DSP the whole range (i.e. OEM head unit) then it doesn't do much.
However, when you have a full range source and the DSP set up correctly (it's not as difficult as it may seem) I guarantee 100% that you'll be amazed at how much better the sound is compared to just dropping in some speakers and calling it a day.
This thread is almost an entire forum in it's self....Raine, you've forgotten more about truck mods than I'll ever know. How far do you plan on taking your truck, what does the final creation look like in your eyes?
There are a few builds on this forum that I hope to sort of model my own truck after, and this is certainly one of them.
Are there any mods you have done that in hind sight don't really seem worth it?
Conversely, if you were given a new truck, what would be your first mods to it?
Dang Raine. Your build is awesome. I love the thought and detail. I just wish I understood electrical, like at all. lol. Your mechanical mods make perfect sense to me. But when you talk electronics and electrical, you're speaking a language I don't understand. I really like the mods where you thought outside the box. I was originally going to remove the front air dam this weekend when I did my lift. But I really like how you just cut off the part that hangs down. And kept the rest of it for a more finished look. Just one example. Thanks for the great thread.
