441 - 460 of 909 Posts
Nice job man! I get some speaker noise with engine acceleration, kinda sounds like a wind up toy, is it related to the small ground cable?
Anyone know if a thread exists for that?
Sent from my SM-G935T using Tapatalk
100% ground wire. Could be amp ground, HU ground or a random ground loop. It is usually the amp or HU (headunit) ground since the static noise starts once aftermarket radio equipment is installed.
Big3 is to give more power from alt, battery etc...
Right on, thanks West1
OP, delete my post if its derailing your awesome build.
@rios, if multiple amps, turn car off and power down one amp at a time to see if you can find the culprit. Once found, using a multimeter you can find a good ground for your amp. I have both amps to my chasis under rear driver seat. With long speaker wire, tie it to Battery Negative. Then connect speaker wire to multimeter negative and find your ground with the multimeter positive.
Discussion Starter #444
Nice. With all the electronics upgrade, did you do the big3 or is that the only ground wire you upgraded?
Looked through the whole thread, great job!!!!
I just upgraded the engine-to-chassis ground since it was obviously a lot thinner than the OEM battery ground and OEM battery-to-alternator cables. I'm still running the OEM alternator so the OEM battery cables are just fine... without getting into a "Big 3" discussion, at this point there's no need to change the other 2 unless I upgrade to a high-output aftermarket alternator. The stock setup has been handling the audio just fine, if anything I will upgrade the actual battery first before considering changing the other 2 of the "Big 3".
Got it.
I've read here about our positive battery terminal that has some type of voltmeter of some sort. Which is why I was asking, in case you got to that before I did lol (I am upgrading to HO alt and big3 for a sound system upgrade).
Keep your build coming, it's a pleasure to read them!
Discussion Starter #446 (Edited)
Absolutely agree - it's a grounding issue of some sort.
@ Rios_rub - I don't know what audio setup you have, but if you turn the head unit off, do you still get the "wind up" sound? If not, then for sure it's audio related. Next, keep the radio on but unplug the speakers. If the sound goes away, it's something with the speaker wiring. If the sound is still there, it's head unit-related. Could be something as simple as a loose ground.
I didn't want to get into this discussion LOL but that's incorrect - doing the Big3 does not give more power, it just clears the way for more power if you upgrade the other parts (alternator, battery) that actually provide the power.
Got it.
IIRC I think it's the ground cable that has the "measuring thing" just a few inches from the terminal, I know there's a thread about it elsewhere on the forum but I don't have the link at the moment.
But yeah, the main 12v+ and negative battery cables are pretty thick already, not like 0-gauge thick but when I compared to my 4-gauge the difference was so small that it wasn't worth all the work to swap without going thicker.
awesome build thread. took me 2 days to get thru it. makes me want to start a build thread just to keep a record of things i do to my truck. I've only added window visors and bed cover but i feel like its not enough yet to start a build thread.
Discussion Starter #448
Thanks
Everyone starts somewhere, who says you can't start your own build thread?
Wow!!!!
This was the best chapter book I ever read in my whole entire life @raine! ::grin::This book was interesting from beginning to end!::wink::It also took me 2 days to get through the whole shebang but it was worth it. ::laugh:: I was reading through other forum member's build threads and they were nowhere interesting as yours! After reading this, I felt like I wanted to go buy a used Fronty and dump my wallet all over it!!!! (Will most probably do this in the future) Even tho I am not a DIY person, this thread was amazing and understandable. :nerd: (I get all my mods done at my local and preferred auto styling shop! I have no xp with these things and the guys at my shop are pretty professional and clean when it comes to getting the mods done. They do not rip up the dash just to install a camera cough cough BestBuy :serious: and since I have been a long time customer, they give me discounts on every mod I get them to do!!!!::smile::::smile::::smile::)
Suggestion: Since you were a ASE-Certified Technician once, you should open an auto styling shop. That way you can have a job that you enjoy doing rather that you "have" to do. Plus, you can steal other Fronty customers from the nearby auto styling shop!>:D (If you opened one, I come and drive from here (Texas) to your place (Cali).
Good catch!
During an air filter change as part of regular maintenance I stumbled upon this:
Thinnest ground wire ever.
No problem, I had some extra 4-gauge power cable from my amplifier install, so I bought some ring terminals and made this:
New ground cable up top, OEM wire on the bottom. Big difference!
...and installed it. Took all but 5 minutes after the soldering iron was hot. Now the engine block has a much better ground:
Proper ground cable.
I really never noticed this under the hood (imma take a look at it when I get the chance). For me, safety is the number one priority so a grounding wire with that thinness is potential accident waiting to happen.
Thanks for noticing this @raine::wink::
(I apologize for responding to an old post. I just got my Fronty last week and I am a newbie to the Frontier, still trying to learn and xpand my knowledge on my lil Fronty. I am not new to Nissan tho)::grin::
Discussion Starter #451
But then it would become a job, and it won't be enjoyable anymore. Plus, if I went that route I'd rather open a mountain bike shop first. Or a chicken rental place, because they're easier to manage than alpacas.
If the post was helpful then it did its job
raine, I am gonna put an aftermarket unit in my truck, I ordered
Main Harness: Metra 20-pin Harness, Ordered
OEM Steering Wheel Control Adaptor: Axxess ASWC-1, had one lying around
OEM AM/FM Antenna Adaptor: Metra 40-NI12 (included with head unit purchase) had one lying around
OEM USB Adaptor: Axxess AX-NISUSB-2, ordered
OEM Rear Camera Adaptor: Axxess AX-NIS32SWC, not sure if this is needed, my truck has NO camera (from factory)
Aux. Front Camera: Pyle PLCM38FRV, not nedded
concerning this part
is there another harness for input of the camera
or do I need to make one?
Discussion Starter #453
If you don't have the factory camera then you won't need it. AX-NIS32SWC is only needed if you're going to use the factory wiring that connects to the factory rear camera. I don't think it's worth the trouble to try to splice into the factory harness to try to make it work with an aftermarket camera, probably much easier just to run your own wires. Depending on how you want the Pyle camera to work (I have the exact same one) you have 2 ways to wire it up:
1. The camera requires 3 wires and an RCA cable (power, switched, ground, and video) At minimum you'll have to run the RCA video cable from the head unit to the camera. Power for the camera can be spliced into the trailer connector at the tailgate, and you can activate the camera by splicing into the taillamp reverse bulb harness.
2. If your head unit allows you to control the camera (and you want this feature) you will have to run the RCA plus a 2-wire harness from head unit to the rear. 1 wire will provide switched 12v to power the camera; 1 wire will connect to your head unit's "reverse signal" wire; ground you can connect to any bolt under the bed or splice into one of the taillamp harnesses.
Just want to say that your build is freaking amazing!
As a newly minted Frontier owner, I already have a wish list bigger than my wallet thanks to this thread alone. (OK, I actually already had a list bigger than my wallet before I bought the truck, but it's about twice as long now. :))
Thanks for the detailed write-ups and the inspiration.
Discussion Starter #460
Don't blame me for anything lol
